Peer81
Hello everybody.
The problem is that me speedo isn't working anymore.
What happend is that I changed the diff ratio so I needed another driven gear to correct the speedo. Inside the 700R4 is a 17 tooth drive gear, I went from a 36 driven gear to a 43 driven gear (with other housing).
First my calculations were off because now the speedo was showing not enough (prevouis to much). But after around 60 miles the speedo stopped all together and stayed at zero.
When I got home I took out the driven gear to see that every teeth was eaten away. As I also had a 42 teeth driven gear I put that in so see how much correction it still needed but the speedo is staying at zero. When I took the driven gear out it still looked untoughed and like new (like it isn't toughing the drive gear). I tried it several times to see if the housing was far enough into the transmission but no problem there. Maybe the inner cable isn't far enough in the drive gear so I pulled it but is was already as far as it could. Tonight I returned the old 36 driven gear with the other housing but still no luck...
I checked the speedo cable all the way to the speedo and no problems. I connected the cable to a drill and slowly spung it around and the speedo was moving according to the speed of the drill. So I think there is no problem in the cables, cruise control module and speedo itself.
I also checked the drive gear inside the transmission. All the teeth are perfect and I cant move or turn the gear so it still seems to be locked into place.
So the question, what is it that I don't see?
Greetings Peter
Greetings Peter
