lone73
I had the left door replaced on my '96 vette due to an accident 2 months ago. The door panel just will not stay in place at the top. After about 10 - 15 door slams it jumps up off of its spot that it is hooked onto and leans inward about 1/2 inch revealing a big gap and is then floppy loose. I have completely removed it and reinstalled it 3 times and it has jumped off again. I cannot figure out whats supposed to hold it vetically downward and hooked into position other than the screws around the interior latch and pull pocket. I have all the plugs along the bottom edge in place but I would add that the door holes for those plugs in this (used) door are higher than the holes in the door panel by about 3/8 inch.
I would go back to the body shop that did the work but they are some serious losers. Already fixed several things they screwed up. Finally got the window to fit the weather strip at the top of the door myself but I just can't seem to get the door panel to stay put.
Any suggestions would be much appreciated.
