J
jrizz1
Problem: The "Down" bumper stop on the drivers side of my 2000 will break off every 2-4 weeks causing the headlight unit not to stay in the down position, and to pop up about half way. I believe the arm is hitting the stop with to much force and breaking it. I have been replacing the bumper stop and the issue keeps returning. I have probably gone thru about 6 of the white plastic stops.
History: The problem started when I needed to replace the stripped plastic gear of the headlight motor. I replaced it with the brass gear.
Question: Is there a preset position to be in when I replace the stop. If you manually turn the knob on the motor clockwise without a stop in place, the headlight unit will continue to cycle up and down.
Thanks for any advise.
