driver information center bulb replacement
  • Thread starter Thread starter ron
R
ron
What is the easiest way to access the bulbs in the driver information center on a 1993? Is there an easier way than removing the center console, etc. Thanks in advance for any advice or information.
Ron
nope, not that i know of, but you don't really have to remove the center console, all you have to do is loosen it, and lift it outo f the way to get to the front part, that surrounds the radio etc.
I have to do this also. Does anyone know what kind of bulb the DIC uses?
TIA,
Steve
DIC bulb replacement #'s
replacement bulb numbers are as follows: ( I assume that these numbers represent GM part numbers - not sure, though)
Service LTPWS 194-1
Low tire pressure 194-1
All other bulbs for all other functions are 74-1
Hope this helps.
Ron
DIC bulb specs.
SR94: I have discovered a cross reference for aforementioned DIC bulbs: #194 is the trade #-the GM part # is 94 21 330 and the # 74 bulb trade # bulb is GM part # 250 85 641.
Ron
Thanks Ron,
now I can get the PKE bulb working again
Steve
