Drivers power seat removal
jenkx
Michigan
Would anybody know how to remove a powered drivers seat that does not work.
I have removed the cushions and I can get to the front bolts that holds down the front of the track.
I cannot get to the back bolts because the motor needs repair.
Sent from my GT-N8013 using Tapatalk
Is the motor in the way????
A couple of mine bolt thru the floor pan.
Sent from my XT1080 using Tapatalk
Bill is right (of course:). They are affixed and accessed from the under-side of the car on the driver's side, the only side with power. I now see why they did it this way compared to the passenger side.
Sent from my iPhone using Tapatalk
I will check access underneath.
I removed the passage from the top and thought the drivers would be the same.
Update to come.
Thank you
Sent from my SM-N915T using Tapatalk
BINGO!
Success on the removal.
Thank you very much for the advice guys.
