Drivers' Side Headlight Not Staying Closed
  • Thread starter Thread starter ron
R
ron
I pulled up the information and the schematic from the knowledgebase concerning this problem, but there are no directions for completing the repair. It seems rather straight forward with only 3 washers and 2 insulators involved as far as parts go. Has anyone done this fix, or is it best left to Mr. Goodwrench?
It lists labor time to be 0.5 hours excluding a coffee break, so it shouldn't be complicated.Thanks in advance.
Ron
Hi there,
Its not bad, just remove the bezel before you start and have someone hold the headlamp up while you install the parts.
2 10mm sockets or wrenches are all that you need.
Allthebest, c4c5
c4c5specialist said:
Hi there,
Allthebest, c4c5
Thanks C4C5, I somehow knew you would come through. I'll get me to land of GOODwrench and order the parts. Thanks again.
Ron
