Bill75
- Joined
- Jan 1, 2004
- Messages
- 698
- Location
- Somers CT
- Corvette
- 75 Coupe ZZ4, Brodix IK-180's, Headers,TK0-500
I'd like to check the tailshaft/pinion alignment but I'm a little confused on the proper method to do it. I've read several papers and I understand the 3 deg max angle and that the centerline of the pinion and the centerline of the transmission tailshaft should be parallel but I don't understand what to use as a "0" reference point to check the angle of each of the parts. Some papers refer to using the starter housing but it would have the same angle as the tailshaft.
Also, what if the pinion angle is wrong, is there any way to adjust/shim it?
