wwr said:
Awhile back I posted about my Dr's car. I found out for sure yesterday what it is. An E55 V8 KOMPRESSOR by AMG. He says he can out run an '04 Corvette. I don't know if he meant a Z06 but he did mean my car a 5.7L. Any thoughts and how strong is this car?
Thanks,
wwr
Base price: $83,220
Vehicle type: front-engine, rear-drive; 4-door 5-passenger sedan
Interior volume, F/R/cargo (cu ft) 51/44/16
Wheelbase 112.4 in
Length/width/height 189.7/71.3/57.2 in
Turning circle 37.4 ft
Curb weight 4087 lb
EPA city/hwy mpg 14/21
Fuel-tank capacity/range 21.1 gal/295 mi
Passive restraints driver and passenger front, side, and curtain airbags; rear side and curtain airbags
POWERTRAIN
supercharged and intercooled 5.4-liter 24-valve V-8, 469 hp, 516 lb-ft; 5-sp auto with manumatic shifting
SUSPENSION
F ind, multilink, coil or air (opt) springs, anti-roll bar
R ind, multilink, coil or air (opt) springs, anti-roll bar
BRAKES
F/R vented, cross-drilled disc/vented, cross-drilled disc
ABS standard
Mercedes-Benz E55 AMG Sedan
Mercedes says that the supercharged 5.4-liter V-8 in the E55 AMG is hand-assembled by a “master engine builder” who vouches for his work with a signature plate affixed to each of these 469-horsepower engines. So, if the owner of an E55 sedan can’t make the zip to 60 mph in the promised 4.5 seconds, he or she has someone to blame. But it’s more likely that people who can come up with the $81,920 it takes to buy one of these sedans ($83,320 for the wagon) don’t care as much about acceleration as they do about image and visual impact, which is supplied in abundance by all of the AMG-badged and -built special items that range from the substantial—eight-piston aluminum brake calipers with larger perforated rotors, and a suspension with specially developed struts, springs, and dampers—to the sublime: Black Birdseye maple-wood trim and comfortable, multicontour sport seats.
This is from Car and Driver. Sounds like a push to me, except the price.
