Peer81
Hello everybody,
My name is Peter and i have a question,
The 96 LT4 vette is from a friend of mine! He bought the vette from Rogers and had it shipped to the Netherlands.
Problem with the goverment for automobiels (or how do you call it in the us) They didn't have a 96 vette with handgears in the centrale computer so no road clearance for this vette!.. But with a German clearance (legal bypass so to say! )it wasn't a problem in the Netherlands anymore, luckely for him! But thats another story...
The Vette was for sale at Rogers and the engine didn't run for over a year (he and therefor i was told) The car has a mod list:
Six Speed LT-4 330 Horsepower Grand Sport Engine
Extensive, Quality Performance Enhancements By Vinci High Performance Including Custom LT-4 Power Package and Custom Power Package Which Includes Modified PowerFlo Thermostat and Constant Monitor Fan Package To Ensure Cooler Engine Temperatures, VHP Performance Computer Upgrade Package, Calibrated To Enhance Performance and Reliability, Underdrive Power Pulley Package, VHP Air Intake Package, 52mm Throttle Body With Air Foil, Low Restriction Corsa Exhaust System, VHP Billet Aluminum Adjustable Fuel Pressure Regulator, Ported, Polished, Bench Flowed Heads, VHP Fiberglass Wrapped Headers, Honed Intake Manifold and Port Match To VHP Cylinder Heads, Motorvac Fuel System, Ripper Shifter Kit, Skip Shift Eliminator, Taylor Plugwire Harness, R&R Flywheel and Clutch Assembly, New Waterpump and Distributor, 4.10 Rear End Gear Ratio-Performance
So a big amount of stuff is from http://www.vincihiperformance.com/index2.htm
Overthere we don't know anything about vinci.... what are the reaction's on there mod's...?
And this is the dynosheet with 2 run's from last week (no air/fuel sheet..)
His and my question is, we think this LT4 could run better numbers then the 325HP and 442Nm, what do you think?
Rogers sayed the enige has around 400HP (don't know if thats block of rear wheels)
Second question, when you look at the second run (dark blue) the torque curve has a weird push from 2200 till 3900rpm, and the torque and hp (ofcourse) have some weird pieks and fall's from 5000 till 6000rpm.
Do you know what the problem could be (we didn't make any more runs) Because the first runs is very smouth and the second is a bit messy, could it be an enginecomputer glitch? Sensors? Some after results for this engine not running for over a year? We don't know... Did somebody over here have some similar problems or could you point a direction?
We didn't check fuelpressure of change it (this is the first time i see it standing in the list :t)
Well, that's about it for now, hope to hear some reply's soon!
Greetings Peter.
Greetings Peter.
