Im about to pick up a set of these Dynomax headers. Does anybody know if there is a difference between the Cyclone Ceramicoat headers and the Blackjack headers? Is it just the finish? I emailed Dynomax yesterday and they haven't returned with an answer yet, and I want to buy some headers!
Summitracing.com shows that they carry the Blackjack, but not the Ceramicoat, but there is an asteric next to the Blackjack noting "available with ceramic coating"
Jegs.com carries a header specifically called the Ceramicoat, as well as the "standard series". Is the standard series equal to the Blackjack?
Also, Im adding these headers with a new engine. Is is easier to:
1) bolt the headers to the engine then install both
2) install the engine, then the headers
3) drop the engine almost all the way in, connect the headers loosley, drop the rest of the way in, then tighten everything up
4) Some method I haven't thought of yet
I noticed in another post that someone mentioned wiring the headers in place, then dropping the engine in, then bolting it together.
Any tips will be greatly appreciated...
Also, does anybody know if these headers are gonna drag the ground?
Derrick
