V
VettesGo95
My E-Brake is stuck and won't go down, how do i fix this ?
I don't understand removing the seat cover as the brake lever mechanism is under the sill cover. The sill cover comes off by removing the rear pillar screws, the sill screws, and sliding the cover out of the front pillar retaining molding, just as you would if you were accessing the bose speaker. The speaker cover is attached to the sill cover. The lever mechanism can then be evaluated to determine if there problem is at the lever itself.
Barrett
