kobi67
I bought a set of four tail lamps on ebay, good price of $200. You see these around $250 from major vendors. When I received them they looked nice, but when I went to install them, they had issues. The inner set do not fit flush to the body panel. The seller was nice and sent a second pair- same fit. What I discovered is that there are a few makers of these lamps, Trim Parts and Keen Parts. I have Keen lamps. I contacted Keen with no reply. I found also that the Trim Parts lamps have all the Guide markings and numbers you will find on the GM originals, Keens Don't have the ''correct" markings.
I will continue my quest to contact Keen about the fit issue, seems like they don't care at this point..
If you want "correct" lamps, make sure you get Trim Parts lamps. Keen lamps look very nice, but do not fit as well and don't have all markings. For a few bucks more, I could have had better.. Hope this helps someone looking for lamps.... Kurt
