Ed Wright Chip
Ethan
Elgin Tx. USA
1991 L98 Coupe
I have a 91 Vette w/Lt4 hot cam kit/Big mouth tpi base /ASM runners/ported top w/ASM52 mm throttle body/also w/all cheap free mods. I changed injectors to motorsports 30lbh cut pressure down to 35 .The engine was so rich it would not run . I bought a Ed Wright chip this helped at least it runs and drives but is still rich. The chip is $350 and since it is a custom chip no returns .Is there a cheaper alternative or should I take it somewhere that dynos and burns chips by reading your engines ecm data?I live in Texas.
Those injectors are too big for a 350, you shouldnt need more than #24s.
My advice is to take those out and sell them, buy a set of Ford #24s.
Those injectors would sure come in handy if you were planning to bolt on a supercharger :gap
I agree with Vader that the 30# are a bit bigg, epecially with a Long Tube Runner.
I will also admit I have 30# on m y Miniram 350, and it is not running rich at all, infact I set my AFPR for 45psi at WOT. It is all in the tuning.
I also believe Ed Wright should be able to fix it for you at no charge, call him and see, if not email me and maybe we can work something out.
I receommend the following:
www.pcmforless.com or Westers www.westers_garage.eidnet.org/Index2.htm
your injectors are too big. I run 24lb Ford SVO's with a TPIS MiniRam and a cam bigger than the hot cam.
Pull em out and put in 24lbs and see if ed wright will update the chip for you at no charge.
