Edlebrock EFI and SuperCharger
  • Thread starter Thread starter fasterthanu
F
fasterthanu
I have seen many chargers, most mount the carbs on top, or there is that new one by vortech that you use a holley 4150 inside of it... Are there any blowers/superchargers out there that you can use IF you install the Edlebrock, or hell, even the Holley TBI systems?
I am not aware of any direct applications. However, I am fairly sure you can get Edelbrock to burn a chip for the Pro Flow EFI that would calibrate for the difference in timing and fuel you need to charge it. The upper horn on the EFI unit is much like a carb, so I assume you could plumb the tube in. Space under the hood will be at a premium as it is tight just trying to put an air cleaner a top of the pro flow with the air gap manifold and a L88 hood.
