F
Fastcossi
Hi everybody here
I am coming from Austria and I am new in this forum, running a 91 C4.
For the reason i have registrated today i like to say first hello again to everybody in here
Using the search function i´ve already tried to find answer to my both questions i have and have also found some posts, but couldn´t find realy the answer.
Today i have seen that may EGR solenoid is not working correct anymore (isn´t thight anymore) so i have to change it but for the 91 the solenoid is discontinued.
Some post indicating that some people have tried to use the solenoid of the 92 model but i couldn´t find any answer if this is realy the way to go and if it was getting working.
Can anybody tell me if it is possible to use the 92 solenoid or if there is an other solution :confused
Second i like to change my injectors. My little vette ist original, no mods to the engine so i like to use standard 22 lbs injectors.
Whas the best solution: use the original again or swap to some Bosch injectors?
If a swap is better, which injectors can / should i use?
Thanks for help in advance
Regards
Fritz
Regards
Fritz
