The reason electric f ans are gaining in popularity , is because, many people have an engine buildup increasing hp/tq and often compression. This all adds to the heat of rejection from the motor which the cooling system and oil has to handle.
The guy before me, replaced the radiator and mech. fan with a 4 core radiator and the twin-fan package from an early 1990's LT 1 Vette (includes shroud for each fan and an entire perimeter enclosure which is almost the same size as the radiator) . This set up moves a hellacious amount of air thru the radiator and i can maintain 180 f. degrees head temp. at idle, in 90 degree ambients. Pulls 22 amps and i have it work off of a Remote Bulb Controller with the bulb in the passenger Head.
The key to any cooling system efficiency are some fundamentals : Make sure the radiator is sealed up good around the sides/same with the a-c condensor, make sure the top radiator seal fits tight against the hood when it closes, run a 180 degree stat , power wash the radiator / condensor /fan blade , dont use any more than 25% coolant to distilled water ratio, use a bottle of Water Wetter, makes sure the inside of the cooling system is clean , make sure your lower radiator hose isnt collapsing at higher rpms, make sure y our water pump is up to the task, pop open the headlights on very hot days to allow more air to come in to the radiator/condensor , and install a heater shutoff valve in the heater inlet hose so no (hot) water enters the dash.
Dave
