MFPvette80
Well, I've fixed my harmonic balancer problem (which I'll cover in a different post) and now there's a new gremlin in my 1980. When running at high RPM (above 3500) or under load, the ignition system seems to stutter. Actually, it's the entire electrical system since the radio and dome light also flicker. Everything looks fine at idle, but when the revs go up or during acceleration, the systems breaks-up. My first assumption is that I have a ground problem since everything goes whacky. Any ideas for a good place to start? I did have the starter motor out over the winter along with the distributor.
