reeferdale
New member
Decided to join the C5 club so I traded my mint C4 vert in for a 99 vert last month (Automatic). Went out last week and car was dead not even a click. I did not even notice if the lights were on the dash. Tried to jump and would still not even turn or click. Charged battery re-installed and fired right up, drove for 1 day no problem. Came out of a store and car cranked fine just hard time firing up - had to pump pedal and hold to floor finally started and drove normal. Next day drove to work no issues, came out of work and same starting issue, had to crank car 5 - 6 time before start. was driving along at 50mpgh and car just shut down, gauges just dumped to the left and no engine. threw it in neutral and it started right up and drove home no issues. Pulled codes - lot of 1016 loss of PCM communication on all modules, these could have been old codes. Cleared all codes and was afraid to drive to work Thursday. Got in Thursday night and test started right up 2x. Friday morning, hard start and cut out on way down the driveway - checked codes only 2 this time IPC 0516 - Speedo circuit malfunction and IPC 1016 along with a RFA 1016?
I checked the battery terminals, they are tight and I cannot see any loose wires or connectors. I am thinking now that the original issue was probably not a dead batteyr but this same issue.
I notice that when I put the key in, the instrument panel lights will flicker rapidly and I will get the no start, hard start condition. If I remove the key and try a couple times I will finally get a clean key insert and normal instrument lighting and the car fires right up. I just ordered the FSM for 1999 C5 but wondering if any experts out there have any ideas for me? I am thinking I may have a short somewhere - but where! I also noticed that a couple times when I turned the key, I got a hard 'clunk' from what I assume was the starter. This only happened 2x and may just be because of an intermittent electrical surge?
thanks for any idea or advice
