electrical problem
  • Thread starter Thread starter LarryK 87
L
LarryK 87
87 cpe right side rear brake lights( and directional on same side) are out, tail lamps work fine on both sides, have installed all new bulbs, and the grounds are intact ( verified by testing ground on left side, and same ground point for right side). what i need is someone with the helms( or equiv)electrical supplement manual. my manual is unavailable to me for the next month or so.
Larry C-4 brake & turn wiring
The stop lamps junction through the hazard switch coming from the pedal
White line is the brake output ( active HIGH )
The LEFT bank is Light Blue ( for turn )
The RIGHT bank is Dark Blue ( for turn )
The LEFT bank for STOP is YELLOW
The RIGHT bank for stop is Dark Green
Brown is running lights
The connector path for rear lights
C-104 ( M Yel / N Dk Grn)
C-209 ( K Yel / G Dk Grn )
I got a problem too!
;LOL
Good luck. :D
_ken :w
thanks ken... i needed that ;LOL
i dont feel anywhere near as bad now....
and thanks Vig, it is in the dark green wire circuit ( somewhere), no 12v present on the socket end for brake, turn or hazard, every thing else appears live. Possibly a break in the column area, will test that this afternoon.
Crkt for Brakes & turn continued
11pin off steering column connector Rt side
15 pin under LOAF
C-403 ( H Yel/ C Dk green)
15 pin Right side of cargo compartment
by rear wheelhouse.
"It is in the dark green wire circuit
( somewhere), no 12v present on the socket end for brake, turn or hazard, every thing else appears live. Possibly a break in the column area, will test that this afternoon."
Monkey with the Hazard switch.. it ALL routes through there..
( Sorry for the LONG delay to finish)
Vig~
nyernga said:
It was a valuable coin! :L
Seriously, it makes it a whole lot easier for me to get in there and straighten out the mess that others before me started, various installer's messes that I instigated by purchasing their products, and the mess I'm gonna make when I begin converting the dash to analog gauges next week. ;)
Or maybe I simply enjoy giving myself headaches! :hb
_ken :w
Vigman:
Found it, it was the connector as it exits the column area, just a weak connection, brake lights and directionals are back and operating. Much appreciated
