A
Alfonso Gomez
My 87 Coupe is equipped with the electronic climate control. I usually use it full blast and the LED display reads "10" as the highest fan speed. The thing is that while driving the fan speed drops to about half for a while. Then it goes back to full speed. A while later it drops down. Then goes up again. It does that all the time even if I set it on "manual".
I took it to an AC shop but they had never done any work on these systems and they did not know if that was the wy it should work or not. They checked and the system has a full charge.
Is this the way it works or is something wrong?
Please help, it is hot and muggy down in PR.
