keremarsan
Hello and Happy New Year from Istanbul / Turkey ,
Please I need help
Last day I had a veru bad experience with my 1988 corvette ,
After the work, I wanted to start my car, but the feul pump did not work.
I forced the car to start without the fuel pump , it started but after it died ( normal ). I tried this for about 5 minutes.
Suddenly, the fuel pump started and engine started normally,
My problems begins after this time :
- Engine can not decrease the IDDLE , Iddle is between 1000 - 1200 RPM
- The Fuel Consumption gauges does not work ( 0 litre / 100 )
- On the road , sometiomes the car returned to normal condition ( suddenly , it indicates the fuel consumption and then again 0 l/100 )
- No error code stored , no engine service soon lamp indication
- I connected A to B on ALDL , normally , I must to get tree times 12 and to finish retrivieving codes, tree times 12 ( 6 in sum ) I get NOTHING
Someting like, DİAGNOSİS don't work.
When I connected A to B, the Cooling fun must work but it doesnt, instead of that, Air Condition is started ?????!!! Maybe some Shortcut ? ECM error ?
Another interesting thing, after connection A to B on ALDL, I started the car with pins connected (something not to do ) , and the car works perfectly !!!!!
I don't have any Idea what can be my problem.
Event with iddle problem and no fuel cons. indicated, car works totally normal on different throttle , no leak of power , no excessiv consumption.
Please , I am waiting for your suggestion ?
thanks all ,
PS: I think to change IACV and Fuel pump and Fuel pump relay but the problems seems to be a more complicated electronic problem.
All other gauges fontions are normal ( oil pressure, oil temp , cooling Temp, Voltage, RPM , Speed ..... )
Please I need help
thanks all ,
