Emblem help
Crosschkm
Chicagoland
93 ANV ZR1, 90 Callaway TT #19, 87 GN,06TrlBlzrSS
;help My Callaway Twin Turbo emblem has come off my TPI upper intake and needs to be glued back down. What glue should I use?;shrug It needs to be able to tolerate heat.
Cross
Cross, although I have not had one come off mine (I have seen others come off though) I know that all the Callaway emblems I have held so far ALL used 3M Brand adhesives - See if there is something here that may help :m
3M Brand adhesives
I used PERMATEX "Quick Set Epoxy" to re-afix my my Callaway SuperNatural 450 throttle bottle cover after the original adhesive began to deteriote from the underhood heat and the cover started to loosen. With the Permatex, its held solid for years.
emblem
I went off the board and used JB Weld. It has worked great so far:dance
Cross
Re: Re: emblem
*89x2* said:
Now I suppose there are 1002 uses for JB Weld ;LOL
Good deal :)
1001 and twin uses for JB WLED:J
Cross
Re: Re: Re: emblem
sherry_ridgeway said:
hi, yes theres a gazillion uses for jb weld, im not meaning to sound like a "bummer" but i hope you dont ever decide to remove the emblem, because thats not going to be easy...sherry:)
I don't want the emblem to ever come off again. The first time it cam off I popped my hood at a car show and it was gone:eek I found it , my spark plug wires grabbed it for me. AND I don't even want to know what Callaway want for a new one if they even have them anymore. If is was a standard corvette emblem I would not care if I used double stick tape, but now I know it aint:nono goin anywhere.
Cross
$50
Is that for the small emblem that is grooved into the intake and says Callaway Twin Turbo, or is that for the large one that sits on top and just says Callaway?
Cross
Re: $50
Cross
that is just a ballpark figure - I inquired about 3 yrs ago...
It was for the Callaway Twin Turbo one
Someone mentioned the other one may be out of production :confused
