B
brit_trader2003
I have a 1969 with a 1979 454 Engine.
I have just had my Gearbox rebuilt by a UK Firm and apparently they had to hammer my Torque Converter of the Engine. After this I had very low (zero) oil pressure. Later I suffered a blown Head Gasket, unfortunately I was doing 70 mph in the fast lane and had to cross 3 lanes of traffic to get to the side of the road. By the time I did the engine was making grinding noises.:cry :cry
I have just had a long chat with a mechanic who has 35 years experience with Chevvy Engines. He says that the UK Firm probably dislodged my Crankshaft a little when they hammered of the Torque Converter. This resulted in low oil pressure. So then my engine was not properly lubricated and cooled and so was running hot. This means that the old engine was getting worn. Eventually the engine running hot has caused the Head Gasket to blow. So water got in and the engine was probably partially seized. Apparently Chevvy Head Gaskets never blow unless there is some other reason. The long and short of this is that between the engine being old and what has happened that there is probably quite alot of damage.
Does this all sound reasonable to you all ? :confused
