grumpyvette
for many years Ive used an engine crane in the shop to pull engines, and it became very obvious that some mods to the system were darn near MANDATORY,
adding an engine leveler and swivel to your engine crane makes things far easier
adding a swivel like this between the leveler and crane GREATLY AIDS THE ENGINES REMOVAL, AS IT PREVENTS THE TENDENCY OF THE ENGINE HANGING ON A CHAIN TO CONSTANTLY WANT TO SWING BACK INTO A SINGLE LOCATION, BUT DON,T GET STUPID or CHEAP, GET THE 3400lb rated one not the 1200lb size (REMEMBER YOULL BE UNDER THAT ENGINE SOMETIMES)
youll need two of these rated at similar load strength[/b]
ever engine crane Ive ever seen came with crappy steel wheels about 2.5"-3"in dia.
" the reasons are obvious they are cheap ,and theres clearance issues for the cranes legs if your pulling an engine when the cars NOT up on jack stands, now I can,t see how you can access all the necessary bolts without the car being up on serious,& sturdy jack stands or a lift, so with that in mind I got out the air/die grinder and removed the tack welded steel wheels and added (6) 8" solid rubber wheels on swivels,
rated at 600 lbs each
yeah, the crane will no longer slide under a car thats not up on jack stands, but then I can,t think of a single reason to use a crane to remove an engine when the cars NOT UP ON JACK STANDS because youll need access to all the bolts holding it in durring the process and youll need to support the trans
YET,ANOTHER GOOD EXAMPLE OF WHY A WELDER IN THE SHOP COMES IN HANDY(welding on new wheels)
this made it SO MUCH EASIER to use its amazingsup:
