rch105
Hi to all!
I'm stumped with this and I'm hopeful someone can help. About a month ago I rewired the connections on an aftermarket XM radio a previous owner had installed. Of the two hot leads, one always stayed hot, the other to the accessory/ ignition switch. I wired both hot. I can surmise that might be part of my problem. About two weeks ago (after not starting or driving the car for 7 or 8 days), I found the battery almost dead. I had to jump start the car with a battery box. Drove it for the day and put it back in the garage. All ran fine. Tonight I decided to take advantage of some better weather (it's been rainy for the past week or so) and upon trying to start it, found it stone dead. I tried the battery box, no go, then a set of jumper cables on a marine battery, no go, then finally hooked up the cables to my running pick up truck...success, it started. Here's part 2 of my problem. After running the engine for a few minutes to help build up the charge, I started to back out of the garage and upon it a little gas, it died. BTW, it's an automatic. I tried to start it and it started right up to idle. Again I put it in gear and started to back up, it died again. So, I let it warm up for about 10 minutes and tried again, same thing...and I did this at least 7 more times with the same results. Now here is what is strange. If I took it out of gear and revved, it is just fine. The engine doesn't die or sputter...but put it in reverse again and it dies with just a little gas applied. So I tried to go forward...does the same thing...it dies. I know I have to redo the wiring to it doesn't drain the battery, but the 2nd part has really stumped me. Any suggestions? BTW, when it was running tonight my panel gauge for volts stayed about 13.4 to 13.5 with only the DRL's on. ;help :bash Thanks in advance. Rick
