Hi there,
You have some variables that need to be addressed.
Yes, first, as you alluded to, your MAF sensor in the air bridge must be completely clamped tightly to the engine. Make sure you dont see anything loose or misrouted.
Second, its definately possible that LT4man is right on the intake not sealing to the heads correctly.
But, the only way to determine that is to look at your MAF sensor readings and fuel trims with a Tech 2.
However, if there was a wire pinched under the intake for the knock sensors, something was left loose or a wire not connected, this could also create the conditons.
I would start by rechecking all the connections, specifically, the vacuum connection at the rear of the intake, below the MAP sensor, for the climate control.
If that is not connected, it could supply just a slight hesitation without throwing any codes.
You can check that by simply starting your engine and listen for a hissing noise from the rear of the engine.
Does this hesitation happen cold or hot??
Allthebest, c4c5
