delorenzos
Does anyone know where the engine suffix id numbers can be found on a 63. If trying to identify my block to see if it is a L75 or L76. Most of the parts point to a L75. Altough, without the original air cleaner things have been changed. The filler neck dosn't have the nipple for the air cleaner. The PCV valve attaches to the carb but it dosn't have threads. The crankcase fitting is for a 64 or later model.
So before I completely restore to original, I want to be sure what motor it is. It has steel valve covers pointing to a 300hp. The block has matching numbers if someone was thinking that. I was told that this was a fuelie, but I think that is a lot of bull.
I just installed power steering, waiting for the coupler to finish. The next project is power brakes. I've been studying what was needed to install when I realized that the vacuum hoses, and crankcase fittings didn't match.
Scot
Scot
