Engine Keeps Running
  • Thread starter Thread starter Imran
I
Imran
Hey everyone,
Just something that I've started noticing recently in my Vette. Sometimes, the car will keep running for about a second or two after I turn off the ignition. What could be the possible causes?
Imran - 74 Convt
are we talking about dieseling?
pos: hot spots (carbon biuld up)?
BerlinaBob here: -as one of your respondents stated, -your V8 is running-on likely owing to carbon/build-up within the combustion-chambers, --which larger particles glow-red and ignite (engine shut-off) any residual fuel-vapor being induced owing to the slight opening of the carburetor-butterflys at their idle-position. Although low-octane petrol in a very hot-running engine (try running a 180*-thermostat instead of 195*; and dumping the fanclutch in favor of a flexfan) is particularly prone to this condition you are experiencing, other obvious first things to check for are: to rich of fuel-mixture (idle-screws settings? carb./float-level to high? carb./metering-jets to large? -or, worn intake/valve-seals allowing oil to be sucked into the combustion-chambers?) which would thus result in creating excessive chamber/carbon-deposits. Some Cadillac-dealers have provided the service of blasting minute walnut-shell particles into the chambers via the sparkplug-holes, and suctioning-out the refuse (leaving the chambers factory-fresh, -while harming nothing). Another "old Mechanic's-trick" (for a fee of $100) is to (without customer seeing), --simply trickle (from your garden-hose) water into the primary(where the choke-butterflys are) Carburetor-venturis for about 5-min while the engine is running at about 2,500-rpm (the engine will slow down as you increase the flow of water, so if you kill the motor pull the hose away IMMEDIATELY, -as you don't want excessive water to create hydraulic-lock by the piston's compression-stroke within the combustion-chamber, which can create serious damage as unvaporized water/liquid will not compress like air/steam). The trickling-water into a necessarily "Prewarmed-engine" is instantly turned into really hot Steam (noticeable at your tailpipe), --which acts to readily soften and flush-out the caked-on carbon-deposits (out your exhaust system), --thus you will find the engine runs more smoothy and without dieseling thereafter. Start with just a tiny spray of water from the hose-nozzle, and increase to a flowing-trickle as you become more confident(brave) with the procedure... :eek Another way of combating the dieseling-problem you are encountering, is to install a simple 12v.dc/carburetor-solenoid so as to plunge-out and impinge against your throttle-arm during normal running, thereby maintaining your throttle/carb.-butterflys at a normal slightly-open (just a crack) position during idle; -but when you switch the engine off, the anti-dieseling/Solenoid is likewise instantly deactivated so as to thereby let the butterflys snap entirely closed (via your existing throttle-return spring), ---thus defeating the dieseling(run-on) because the engine is thus entirely prevented from breathing (no air/fuel-mixture can pass in via the fully closed butterflys). Many later cars employed this technique from the factory, -as a way of addressing/defeating "dieseling"-complaints by concerned drivers like yourself, who sense that that violent/dieseling-action can indeed be harmful to an engine's pistons & conrod/wrist-pins...:s
Imran,
Has your car been upgraded to electronic ignition?
Mike
Stingray6974 said:
Imran,
Mike
Yes it has... The problem just started recently, and the HEI ignition has been there for a while... I was thinking the fuel-air mixture was not right, because sometimes the car gets flooded as well and I have to use the full-throttle trick to get her started. But again, that happens just rarely.
Imran - 74
Get on the highway and stick your foot in it and blow some of that carbon out.........:bu
Does the motor keep running normally then shuts off or does it act like it's dieseling?
Mike
Mike
Mike,
I've never had a car that diesels before, but the car sputters and then shuts off. It doesn't keep running normally.
BTW: The engine temp runs normal... well, according to my temp gauge that is.
Cruzer, I like your idea, will try that tomorrow too ;)
Imran-Beautiful Corvette you have there.It`s interesting because I just started having the same problem about a week and a half ago.It will just sputter then die after turning off the key.Also when I start it in the morning it will turn over and start then idle and die like it`s flooded.After that it starts just fine with no problems.
BBF,
when it dies in the morning, are you sure it doesn't run out of fuel. If it's the stock carb I'll bet that you have a leaking fuel well. Most people epoxy them so they don't leak.
just a thought.
tom:gap
It could be I`ll have to check a few things.My connections at the alternator,distributor.My ignition timing,also I have recently raised my idle speed and that may be the reason for the dieseling after shut off.
