M
Mikey1
was driving through some country roads some days ago and was quite pushing and revving the engine. After w a while...driving back....I had some problems which I assumed to be partial ignition failures...
it looked to me as 2 cylinders were not working properly....and I heard a popping noise of fuel exploding in the exhaust....
...also idle dropped down from 800 to somewhat below 600 and the engine would die if I would step on the pedal....however it was revving up more or less correctly with no starving beyond 4000 easily (I stopped it there in order to not break anything...).
I changed ignition cables to a complete new set, dist cap is new as well...underneath is a breakerless ignition...and there is a spark on every plug which I tested as well.
However...sparkplugs of cylinders 2 and 3 have been wet of fuel....
....all the others have a light brown color....I use Delco R43 plugs.
After all that checking had been performed I feared something like a dead camshaft....or even worse and went for compression testing.
Result down below:
For my eyes this looks ok with no dramatic differences whatsoever. That means to me, that valvetrain and possibly piston rings are ok.
Today I went to check valve play which turned out to something between 0.02" and 0,035" with a cold engine (AIM says should be 0.03" hot. Is there any value that one could use for a cold setup ?).
This is how my valvetrain looks.....all springs seems to be ok.
Only thing that I found interesting is that the one rocker arm on the outlet valve of cylinder #4 is slightly more out of angle than the others.
With my Digitalcalipers I tried to measure the valve lift....but that was a bit difficult...only telling that they're all something around 0,377" ....with to many sources of false measurement. However this tells that the camshaft seems to be ok....at least no major damage.
Well....my current consideration is that something has to be wrong with the timing chain....maybe it is lengthened and revving the engine quite hard made it jump by just one tooth....
...any thoughts ? I would appreciate your comments.
THX Michael
Result down below:
THX Michael
