Make a realistic plan
I would design the engine for the intended rpm range for most of your driving. For example, if you're going to stick with the powerglide automatic and drive on city streets, you'll seldom see more than 2,500 rpm even with a 3.70 rear. The easiest way to get more torque in that low rpm range is to install a small block 400 with a very mild cam.
If you will switch to a manual transmission, install a 4.11 rear, and drive like a 16 year-old, then you can soup up a little 283 and feel some power in the 5-7,000 rpm range. Of course the engine will be a very weak suck below 3,000 rpm and you'll have to replace some drivetrain components as they break under high rpm load.
You can forget the magazine stories about getting 350hp out of a 283 unless you want a car suitable only for drag racing. Look carefully at the dyno results in these stories. You'll see that they seldom mention torque / horsepower figures below 3,500 rpm, let alone idle rpm or off-idle engine response. The only realistic way to have it all (useable high horsepower, reasonable economy, low maintenance) is to install a huge engine, mild cam, and a transmission / rear combo that gives a high ratio number in low gear and a low number in high gear.
