ft laud mike
Hello all,
Had same problem a while back, thought it was fixed. when driving the car will skip and stutter under acceleration. The first time this happened i went with the easiest (cheapest) solution and changed the feul filter. This helped, the problem went away for about 6 months. yesterday it reappeared. After the car sat for a while at a friends house on thedrive home there was no skipping.
My thought is that it is vapor lock (heating of the gas inline), but why would this suddenly appear (ive made no changes to the engine or compartment to change underhood heat). The other thought i had was failing feul pump. while the car was sitting at friends house i looked at the new feul filter which is clear. there was no fuel in it. is it normal for the fuel to drain from the line like that?
any help would be appreciated
thanks
mike
1970 454, 4 spd, edelbrock torker, holey dbl pumper, jet hot coated headers, msd6 box/coil
thanks
mike
