C
curvhog
I'm looking for some help with a mystery problem with my 2007 Convertible with Auto trans.
3 times in the last 500 miles the engine has stopped running and sets no codes that cause the service light to come on. Each time the situation has been different but the symptoms are the same. First time the engine died backing out of my garage (engine cold) and after nearly two hours of waiting for the protection plan tow truck to show up I gave it that one last try and it started right up. Seeing no codes I talked to the service rep and decided to wait for an upcoming oil change to get it checked.
2nd time afer 45 mins or so of steady driving it died getting off the freeway. When it dies it's like someone turned off a light switch on the engine everything else works, the engine cranks but won't fire, no codes set. That was 3 days ago, had it towed to dealer, car started fine when dealer tried it about 2 hours later. Dealer could find nothing stored and with a little urging he replaced the power module relay (his best guess). Picked up the car drove ten miles, had a beer and pizza, got in the car and no start, same symptoms, sputtered a little like it had spark but no fuel. I had the tow truck leave it at the dealer but unfortunately he couldn't figure out how to lock it properly so by the time the service guys got to it this morning the battery was dead not a chance of getting a code and it started, but once again while I was trying to start it I did not see any light saying a code was set.
Dealer has tested everything possible, talked to factory engineers, so far no solution.
Anyone with a similar problem-an idea that makes sense I'm listening.
