Okay, I'm in the same boat but need to use epoxy on my rear clip since it's a late car with smc panels.
Epoxy is stronger but there's a catch.
On a vette you use chopped strands matte since the woven cloth will show through the paint (unless you're using it on a part that doesn't show but needs strength, woven matte is stronger than chopped strands matte)
Here's the catch:
You can use epoxy on the woven stuff and it will come out fine, you can't on the chopped strands matte. Why? Chopped strands matte needs to crosslink in the matrix to get the desired strength and for this you need styrene, the problem is, epoxy resin doesn't have any styrene in it, polyester does, that's why you don't use epoxy with chopped strands matte.
Now since vettes are to be repaired with chopped strands matte and the general decided to use SMC we have a problem, polyester doesn't stick to smc all that well and epoxy can't be used with the correct matte. Now Ecklers sells a special laminating resin for SMC wich is epoxy and can be used with crushed fibers. I think they mixed styrene into it but don't know for sure. I emailed Adtech who makes the resin Ecklers sells but they haven't replied to my email (and they probably won't as most companies don't know what customer service means nowadays). I can't get the stuff here since they won't ship hazardous materials overseas.
Epoxy isn't harder to work with, you just have to be a bit more precise measuring the ingredients.
If I were you I'd use normal polyester resin and chopped strands matte, it's a proven method, no need to get fancy (plus expensive, epoxy is more expensive too)
I hope Chris is reading this so maybe he can give some insight on this subject. I've asked on another forum and sadly I don't think anyone there knows, they just say get the Ecklers stuff, I would if I could.
Also since the subject was brought up, is there anyone who has used epoxy resin and micro balloons to make their own filler?????
I seriously dislike most of the commercially available filler, most are too grainy, come off easily or harden waaaay too fast s so if someone has had good results with micro balloons I may be tempted to use that
Marck
