btr85vette
New member
I recently had a problem where my 85 Vette suddenly would barely run. I checked the error code, and it threw a code 33, MAF sensor voltage high. I bought a FSM from Ebay, and went through the diagram, and found something interesting.
After going through the diagram, and tearing part of the car apart to find the Burn Off module, I happened to notice on the wiring diagram in the FSM that there was a circuit going to the gauges. So I went to the fuse block and found a 10 amp fuse for the instrument panel, and it was blown. I replaced it and the car ran fine again. I had one of the instrument panel bulbs blow, so maybe they're related.
The whole point of this post? While the FSM has great info, it NEVER said to check the fuse! I spent a week and a half with my car down, and all I had to do was replace a fuse.
Long story short, on an error code 33, check the Instrument panel fuse first.
(and yes, I know, I will be monitoring the circuit to see why the fuse blew.)
