Shawn's 78
So in my quest to eliminate and determine my vibration around the 3000-3500 rpms, i've replaced all my belts, fan clutch and the harmonic balancer. The harmonic balancer was in the worst shape; I could just about push the two pieces apart with my hands. :eek
So after that is all said and done, the vibration has lessened, but still exists.
QUESTION: Could harmonics from exhaust cause this type of vibration?
It's a stock L48, new clutch and mods made above with 2-1-2 exhaust in which the cat has been modified (pellets removed by previous owner). The exhaust is original from what I can gather (production dates on the actual exhaust itself).
Is it possible that the exhaust is causing a "harmonic" due to the modification of the cat?
Has anyone run into this or noticed a change when they went to true duals?
Would it behoove me to replace the exhaust first, then dig into the tranny / clutch (previous owner replaced the clutch, turned flywheel etc). Our would some of you vets think it may be the clutch?
Any advice would be helpfull
Shawn ;help
Shawn ;help
