74bigblock
OK... So I've got a leak between the manfold and the exhaust pipe on passenger side. Why? Cause there is no doughnut gasket in there. Drivers side does not leak because some moron used silicone to seal it! Here is what I need to know.. hopefully with your help I can resolve these issues:
1) I need to know how the correct setup goes together. Some places sell a gasket, and others a gasket and a riser, and others a gasket and a Heat riser. Which is the correct set up for my 74 454?
2) Once #1 is resolved, how do I go about getting the center cross member down (The pipes are welded and go right thru the center of it on either side of the trans)? Will I need to drop the trans to do this?
