BarryK, a member of the CAC sent me a "pm" a couple of years ago about a product and procedure he used on his car. Here's what Barry sent me - if it comes out as nice as Barry stated, it's a LOT easier than pulling the manifolds:
Hi
sorry, I can't currently take and send you any pics of the exhaust manifolds because the car is in the shop getting a new paint job.
If you saw the thread in which I reported using the Dry graphite Film Lubricant the pictures don't do the product justice - they came out looking very nice in my opinion. Better pics of the results can be seen on Paul79's car in a current thread which is here
http://corvetteactioncenter.com/foru...ad.php?t=57399
The second pic in the first post in the thread (the green car) is Paul's and the graphite spray use was his idea that I had used.
I can say that the exhust manifolds on my car look just as good now after approx 1000 miles of driving as they did when i first applied the graphite spray - there is NO change what so ever to how they look. It's not wearing off or baking off from use. The only thing I have found is NOT to use a heavy-duty engine degreaser cleaner such as Gunk on the manifolds after applying the graphite spray. I found this out the hard way - a day or two after initially doing the mainfolds I decided to clean up the rest of the engine and used a lot of Gunk cleaner to get a very clean motor. The Gunk removed some of the graphite causing a "spotting" look. I reapplied the graphite spray and now only clean the motor down with water or more mild cleaners and rags and the exhaust manifolds continue to look very good.
A friend of mine also used one of the other products on the market designed for exhaust manifolds but also like you found that it didn't last very long. Using the Dry Graphite Film Lubricant was very easy, very inexpensive, and is lasting a long time. I believe in one of his previous threads Paul79 said that so far it's lasted 2 years for him without having to re-do them.
Even if I do have to do them again in a year or two it only takes about 20 minutes total for the job and a little more than 1/4 can of the graphite which only cost approx $4.00 so any possibly reapplication in the future won't be a major hardship!
LOL
The graphite I used is from NAPA is is called NAPA dgf123 Dry Graphite Fil Lubricant.
You can also find this under different names. One of the important things is to make sure it's the aerosol can AND the contents also include propane.
To apply, spray some from the can into a cup until you have a bit of a "puddle" in the cup. Immediately dip a small paintbrush into the cup and than paint it onto the exhaust manifolds. You will need to work fast and also not spray too much into the cup as the propane causes it to dry out very quickly. After one or two dips into the cup and painting onto the manifolds spray more into the cup and continue.
Don't be concerned when you see the graphite in the cup and first on the manifolds. It will look very dark black and MUCH darker than desired but as it drys it turns to the dark gray color you see in the pic.
I hope this helps
