69MyWay
I need to hear from those that have been there and done it. That is building and bonding the front clip. When is the best time to do it.
I have settled on the big block build for my car. Right now the body from the firewall back is shimmed and bolted to the restored frame. I have stripped, sanded, and covered the rear body and doors in high quality eurothane primer. The final look for this car includes a smooth firewall, with complete color match inner fenders and firewall. I am running the Vintage Air super cooler II compact and thus have eliminated the entire air box from the firewall.
The front clip and inner fenders are all aftermarket parts. I am aware of the hand work needed to get them to fit correct. I am a few days away from having it assembled.
Now--do I:
1. bond the front, hand fit, sand, prime and paint the car then drop in the motor.
2. Set the front clip out of the way, paint the firewall, build and instal the motor-then bond the nose, hand fit, sand, prime, and paint the whole car.
3. bond the front, hand fit, sand, prime--paint the firewall and inner structure, install the motor, then paint the whole car.
The way I see it, 1. makes the most sense for a number of reasons. Option 2 allows for easy access to the engine, less back strain, and more room to work on things. Option 3 allows for mistakes and damage to the body, saving the paint for last. My only worry on option 3 is getting grease or oil on the bare primed parts causing paint problems.
What do you think?
Now--do I:
What do you think?
