T
Tedmag1
After changing bad injectors on my 89 the idle upon the first start was up around 1500 rpms I quickly lowered the idle adj screw all the way down to get to 600 rpms at a stop in drive, I adjusted the tps to 0.54 volts but now I have to tap the gas pedal when comming to a stop in order to get it to idle down it is like it hangs up I am not sure if it is the IAC valve or the linkage isjust hanging up a little,it runs excellent except for that, and the first initial startup takes an extended cranking I adjusted my fuel pressure regulator to 47lbs key on not running, any ideas would be welcome by the way the injectors were purchased fron jon at fuel injector conection
