F/S: 1968 Long Block 327 #3914678
sundevil74
New member
Leavenworth, Kansas
1971 Mille Miglia Coupe, 454 4-speed
ENGINE CASTING # 3914678 ASSY DATE – J177 (10/17/1967)
(11.0:1 c/r, 1968 302 c.i. for Z-28 Camaro / 1968 327 c.i. for Corvette, Camaro, Chevelle / 1968 350 c.i. for Camaro, Nova)
HEAD CASTING # 3890462 ASSY DATE – H176 (both heads) (7/17/1966)
(66-67 “camel hump,” 63-65 cc chambers, 2.02 / 1.60 valves, no accessory holes)
CRANKSHAFT CASTING # – 4672 (forged, medium journal)
INTAKE CASTING # – 3890490 ASSY DATE (under oil splash shield)
(1966-67 / Aluminum with Winters snowflake / hi-rise Holley / 350 HP)
CARB – Holley List-1850-2 (4160) 600 cfm Vac Secondaries. Needs rebuild.
Essentially a long block minus CAM (block / complete matched heads / crankshaft / intake / carb / pistons / rods / balancer / oil pan / oil pump / dipstick / engine bolts).
Pad is clean, no VIN or suffix. Pistons marked .030 (bored .030 over?). Was running when pulled and disassembled. Stored since 1995. Sweet motor!
Asking $1200 for everything. KC area. Mike
