[/IMG]One of these has a little below the bead "dings" from dismounting. Goodyear tech says not a problem if the installer uses a little sealant when mounting to assure airtight seal. One of the tires has 1 rib that is 5/32 and the balance of that tire is 8/32 (weird) Very reasonable at $270 for both tires SHIPPED to you in the contiguous 48. Bead "ding" is in 2nd pic..............
