HI there,
There are so many theories on this 'Dexcool breaking down', yet there is only fact here.
First, Dexcool must be mixed correctly with regular drinking tap water, and in no more than a 60% water/40% Dexcool. 50/50 is ideal, but in the hotter states, some run 60/40 and that is ok.
There are 2 major reasons for Dexcool to break down.
First, water that it is mixed with is contaminated, creating a chemical reaction, thus breaking down the mixture.
Second, contamination from combustion gases entering the cooling system. IE/ leaking head gaskets, leaking intake gaskets, cracked cylinder heads.
As far as using distilled water, I prefer that, but it is NOT required.
I make sure I test all cars at least once a year for electrolysis and contamination. This will ensure that you do not end up with the muck and sludge buildup that so many people complain about.:W
I have so many customers with many different kinds of vehicles that have over 100k, with no problems, so I really would not worry.
Like anything else, it required periodic checking and maintenance.
Allthebest, c4c5:W
