Factory Mobile 1 Decal Location
  • Thread starter Thread starter DanMan
D
DanMan
Does anybody have a picture of the exact location where the factory Mobile 1 Decal is located ? A picture would be great. I figure since I use it, I might as well advertise it properly...Thanks in Advance !
Newbie practicing his Wave-
what year corvette do you have? when they started using the mobil 1 emblem mid way through '93, it took the place of the assembled in bowling green emblem under the hood... center, bottom between the headlights... i can take a pic tonight if you want, but it may not be worth it if you already have the bowling green one.
Your correct...its an 87 and it does have the Bowling Green tag there. Thanks for letting me know.:)
The factory did not begin to use Mobil-1 until the LT-1 motors in 92 and later C4's came out. The factory dropped the L98 oil cooler as synthetics did as good a job of providing the necessary lubrication at high temperatures seen in the LT-1 as the oil cooler did in the earlier motors with the oil cooler. That was a cost savings to GM by not having to add extra parts to the LT-1 motor.
I think the only prior use of Mobil-1 in a L98 was the twin-turbo Callaway (RPO BK2).
