boomdriver
ad
Alright.....this is war !
As if I did'nt have other things to do. After finding at least 5 things that could have been responsible for the 1st smog failure, and correcting each and every one AND doing a major tune up, I felt confident about the retest.
Failed with only slightly better numbers than last time.
Whats been done so far:
NEW wires, delco plugs, cap & rotor. New IAC. reset TPS and ign timing. R&R throttle body to clean and install new gaskets,. Ran alcohol blend thru test.
Checked each fuel injector. 6 were at 17.0 and 2 were @ 16.9 Nowhere near faulty. Fuel pressure is 37lbs and holds for 1/2hr before dropping.
The ONLY things left are the Cat and/or the o2 sensor which I cannot break loose....
Any suggestions? I am at a loss.
The texas smog test are rigged....anything that 96 or newer gets smogged off its own OBD-II system. Anything under 1996 gets the dyno and I've been told that the spec is MUCH harder to achieve on top of the smog machines NOT being maintained and calibrated as often as they should be due to the cost of that maintinence.
All well & good, I still need a smog cert ! ! !;help
