Fan cutout switch
  • Thread starter Thread starter 1984C4
1
1984C4
Does anyone have a wiring diagram for the radiator fan that could check something for me? Just changed R4 compressor, accumulator and orifice tube and flushed. Pulled a vac for 3 hours and it held rock solid for 20 hours so I charged her up and have nice cold air. While trying to swap the fan cutout switch from my old comp to the new it cracked and became unuseable due to very brittle plastic. Ordered a new one and it came with a different style plug so I had to splice it on. Problem is now my radiator fan runs anytime the key is in run. Also the compressor clutch will engage with the engine off and key in run if ac is selected. It never did either of these before. The fan would run when the ac was turned on and shut off when ac was selected off unless the engine was still hot and the water temp switches kept it running. I have 12 volts to the switch any time the key is in run whether the engine is running or not. I think I heard this switch operates at 150 psi. Does that mean it should only come on when the ac is selected on? I have continuity through it with the engine not running so shouldnt the pressure in the comp be less than 150 psi? I think I put a switch on that is stuck in the closed position and it cost me $26.00 and now probably 2.75lbs of R12 to have it removed for troubleshooting!! Anyone know if this is a normally closed or normally open switch and know its working pressure?
Thanks for all the help (sarcasm). I figured it out with help from another web forum.
Thanks Bill. Those diagrams are great! Funny thing is the fan cut out switch is not shown on the AC schematic and I didn't see a schematic for the fan itself. I'm just glad that my car is finally fixed even though it seems like summer is almost over up here in Maine. Save the wave. Mike
Torque Shop
Dream Giveaway
