All of the electrical is correct, shows fans operating, a/c on, etc., but no air being forced through. Air blowing in is just outside air as I drive. Help!!! Is it a fuse and if so, which one? Thanks!!!!
I have to get my book
I'll bet it's the one on the passenger side floor
pull the cover.. the functions are labeled on the box cover.. the interior one has all the cabin functions on it.
For the one under the hood.. If there's an AC fuse check that as well.
Thanks, Mike. The A/C works! It is basically just that there is no fan blowing the air through the vents although the display shows that the fan is on.
Hmmmmmmm
When did this start being a problem?
Do you leave the car anywhere that it's exposed to alot of leaves... that could get sucked into the air intake for the blower... ( Small leaves & twigs leaves jammin up the fan)
Find the blower motor connections, make sure their secure.
HI there,
Your blower motor fuse, depends on which HVAC you have, as if you have dual zone climate, then your motor is controlled by the programmer.
If you have standard, then it is controlled by the switch itself.
Check BLO MOT maxi fuse 51, located under the toe board, if you have the either HVAC system.
If you ahve the standard system, then check HVAC minifuse, in the same area. Also, you will have a blower motor relay on this system, which is directly above the fuse panel, in the toe board area.
Let us know what you have, as the blower, is under the passenger side dash, and can be accessed.
Besttoyou, c4c5
We have the dual climate control. When checking the fuse box, we don't have a MAXI-Fuse 51, but the BLOMO fuse was 49. Checked it and it seemed to be fine. HELP???
No access to my book
The friend I lent it to, well lets just say they are destroyed. I'm buying a used set from Racer 78
but it will be more than a week before I can dig for the info you need...e mail me later, I'll be glad to help if you can hold out.
Hi there,
Your next check will be power into the motor, on the orange wire.
You will not get a full amp signal. It will be pulse modulated, so your voltage will fluctuate, however, you should still see battery power.
Let us know, c4c5
my fan does not run and the blower control (up &down) does not work. any ideas???? checked bloMo fuse 30 amp and it is good. going on trip and I really need the air to work. thanks
