Tsker79
Well CAC members, you've helped before, so I know you will be able to help again. I am trying to remove the Fan Shroud in my 79. I've referenced two manuals that I have with no luck. I've removed the fan from the center pulley, the air intake is off, the air cleaner is off, the shroud is unbolted, BUT, I cannot get it to come up and out. I've also disconnected the wiring for the electric fan. Any suggstions definitely will be appreciated.
