fan shroud
kelly3
pampa tx
1981 red
how do i in stall a new fan shroud i took off everything that was in the way an it still wont slide in thanks kelly
You have to pull the fan shroud back towards the engine as far as possible. Then remove the radiator. You will then have enough room to remove the shroud. I've done it at least 4 or 5 times over the years and really isn't that difficult. Just have a buddy help lift out the radiator.
thanks dave that did the trick merry christmas an a happy new year to u an your family
