dshanks
Im in the process of re-assembling the front end of my engine to get it started for the first time after an 8 month restoration, and I thought I was going to be driving this thing tomorrow night.
Well, the worst $#!+ happened! I was removing the upper bolt on the water pump (which I just installed, brand new, just 3 weeks ago in a fresh motor) to install the Alternator brackets, and as I was removing the bolt, (new ARP fasteners) and it sheared off in my NUMBERS MATCHING block. I couldnt have been more furious! At me, ARP, the car, whatever...Im sure you know the feeling...
What's wrong here? I read they are good to 170,000-200,000 psi. Im no engineer, if somebody knows what I did wrong here please let me know...
More importantly, how do I fix this mess? I can make a different bracket to mount to the manifold and drivers side head, run 3 water pump bolts, call it a day, which might be a pain in the ^$$ and un reliable or I can drill this thing out and re-tap it. If thats the best solution, what type of bit would cut through a grade 8+ bolt? and when I get through it, what size tap do i use? It broke in the block about 3/8" so Im not drilling onto a stump, thank god!!! is it promising???
Is there water jacket on the other side of the upper bolt like the lower? Do I drill on through?
Should I consult a professional? The car doesnt run yet, and I cant afford a tow to a metalurgist and back...
My engine has fresh orange paint, so torching to expand is not the best option...
The bolt was very hard turning, obviously, so an easyout will probably not work...
Should I have a new motor built and save this #s matching block for another day when I have more time and money, when a trip to a proper machine shop isnt out of the question?
Does anybody agree that I should not have been able to shear that off with a 1/2" hand rachet???
Hope I provided enough info, if not please ask.
Give me a break ARP, I hope this wasnt your fault, I though you were the best...
