I switched from the 330 'glass to a 7 leaf
I recently had a rear end changed - the only "ultimate-end" part I've put on the wee beasty to date.
(Wanting a monster-powered stroked BB one day, I wanted the strongest IRS suspension I could get, so I went with the Tom's Differential 12-bolt with 3.70's, which pretty much nuked the 'ole CC's by itself.
Not having enough credit left right then to even put on the "1480"
0.135" axle kit at the same time, I DID at least have enough to change the anemic spring, which was a 330# fiber spring.
I had intended to go with the #360 - or there is like a #420 or even heavier listed in the VPB catalog - but my vette shop talked me out of it.
When I get sidepipes for der oberstmotor, I WILL go back to the fiberspring, and that's the hint of why my vette dude doesn't like them on the rear - while he does like the front transverse leaf conversion which also uses the fiber springs.
Heat.
Even with the insulators of several designs and with a nice 2.5" pipes, the fiberspring is awfully close to the pipes.
I had been concerned with this when my muffler shop had been doing some work back there, and it was the opinion of the vette shop dude that the fiber spring was likelier to experience heat degradation than the steel spring.
I have to say I preferred the ride of the fiberspring, although like not bottoming out all the time. The action is definitely different (as one other responder mentioned.)
Cost is a factor - the HD 7 leaf (which is 420# I believe) is only about $100. The fiber (in any weight) is $300. The weight is WAY in favor of the fiberspring, but that heat concern I feel is valid with under-body pipes.
Now if only my trusty, heavy, cheap, strong REALSTEEL spring had managed to prevent my driver rear wheel from blowing off the car at 80, things would have been MUCH better!!!
